How to send Radiation data?
Hello
i have an GQ GMC-600 plus and want to send my data to your website .
Can you tell me how to do that ?
Many thanks in advance
Menno
For now sensor.community only supports the Multigeiger which does not use this GMC-600 Geiger Zähler.
However the data is not displayed on the Sensor.Community map but here:
https://multigeiger.citysensor.de/
Check the github in order to code a firmware which can forward the values from the GMC-600 Geiger serial port. It would be possible to add “GMC-600 Geiger” in devices.sensor.community for the registration.
But are you aware that the SC database is not made for mobiles devices ? The GMC-600 Geiger would have to stay in the same position.
