[Edit, realized this was in the FAQ and it is not an FAQ]
Hello everyone,
I have been through the sensor setup, and registered the device.
I am using a Raspberry Pi4 with a BMP280 and a HM3301.
Right now the temp / humidity and pressure are working like a champ and publishing online and on the map. My HM3301 data is showing up under the device data but not showing up on the map.
I am using Node Red to grab all the data and push it to the API, I am just lost as to what is happening between data received at sensor.community and putting the data on the map. Thoughts or ideas?
particulate matter sensor HM3301
| Sensor ID: | 62106 (show on map) |
| Last updated: | 13.05.2021, 21:21:14 |
| Fine dust 10 µm: | 3 µg/m³ |
| Fine dust 2.5 µm: | 3 µg/m³ |
temperature/pressure sensor BMP280
| Sensor ID: | 62107 (show on map) |
| Last updated: | 13.05.2021, 21:20:14 |
| Temperature: | 24.99975 °C |
| Humidity: | 39 % RH |
| Pressure at sea level: | 1011.77 hPa |
