I built an Airrohr according to the instructions on the Website.
The setup is as follwing:
ESP8266
SDS011
The Sensor SDS011 is sending data when it is turned on, but the values are completly off (750 - 900 μg).
I also recognized that the ESP gets really hot which seems wrong.
With little to no prior experience I am not sure how to proceed.
Help is much appreciated
@Ju_Li
On the configuration site (192.168.4.1/config) go to the settings and there look if there is a multiplier in the setting. For example 250%. This multiplies the values with factor 2.5…
Tell if you need help…
There is no correction for the SDS011. Can you find a local community next to your home. Look at the map => the option to show the pins for the communties contact has to be reactivated.
