I have had a new sensor kit SDS011/BME280 sensor ID 5423193 for a few weeks
It is very annoying that this system fails regularly, i.e. it is not stable.
However, the WLAN connection remains active.
I have already exchanged the Node MCU ESP8266 and flashed it again, unfortunately without success.
What else can I do to make this system stable?
pjg
2
Just get a better USB 5V powersupply with at least 1.5A.
The symptoms are those a weak PSU.
Thank you for responding,
After connecting to USB 5V 3A power supply the same symptom… still not stable…
pjg
4
Is there the wps Option on the Router ?
pjg
5
Can you send me the serial log ? Plug a usb câble and read the serial with the arduino ide or screen in bash
I just flashed the ESP8266 again and oplaced a node of the mesh wifi system near this.
I will try this first.
Router has a wps button.
This is the device status after flashing.
|Firmware version|NRZ-2020-133
ST:1
SDK:2.2.2-dev(38a443e)
Core:2.7.3-3-g2843a5ac=20703003
lwIP:STABLE-2_1_2_RELEASE
glue:1.2-30-g92add50
BearSSL:5c771be|
|Free Memory|31632|
|Heap Fragmentation|2 %|
|Last OTA|6 min, 58s|
|NTP Sync|1|
|NTP Info|86.85.103.243 (0.pool.ntp.org) reachable: Yes|
|Time (UTC)|Mon Jun 27 15:23:49 2022|
|Uptime|6 min, 58s|
|Reset Reason|External System|
|SDS011|21-01-12(ecf3)|
|only errors|
|WiFi|0/-47/0|
|OTA Return|200|
|SDS011|0|
|Number of measurements|2|
|Time spent uploading|2301 ms|
pjg
7
This looks normal. Can you get the following logs?
I placed a router mesh node near the ESP8266 and the problem seems to be solved.
The WiFi signal is now 100% and connection seems to be stable now.
Many thanks for your help.
Now something strange occurs. I can see my sensor on PM sensors - Grafana (madavi.de)
but I can’t login with my IP adres 192.168.1.10 (check IP adres on my router)
