ESP32 LoRaWAN based Noise sensor not visible on map
The measurement data of my new LoRaWAN based noise sensor (devid: 83880) are not visible on the map, but I can see the data on my account at devices.sensor.community | käyttäjäkonfiguraatio. The data arrived every four minutes from my Logstash based forwarder, see my post on topic: Getting noise data into sensor.community - #6 by Roland
@Roland , at the moment the sensor is marked as ‘indoor’. To show indoor sensor on the map you need to activate the appropriate option in the menu that is opened by clicking on ‘PM2.5’ in the bottom left corner.
@ricki-z thank you for your help. I set the sensor to outdoor, now the sensor is visible on the map. At the weekend I will place the sensor on my balkony.
