I modified the original firmware to do an ESP32 only firmware.
The https seems now to work for this board.
Still a few correction and implementation of the auto-update needed.
Feel free to test and give me feedback.
What is the benefit compared to esp8266? Bluetooth Support for configuration or so?
More place for the firmware.
Better stability for the Next PM for example.
2 full working UART (+ the serial reader).
More pins.
I tried to compile the esp32 beta source, but had no success
* Executing task in folder airrohr-firmware: C:\Users\andre\.platformio\penv\Scripts\platformio.exe run
Warning! Ignore unknown configuration option `lang` in section [env:esp32dev]
Warning! Ignore unknown configuration option `lang` in section [env:esp32dev_de]
Processing esp32dev (platform: espressif32; framework: arduino; board: esp32dev)
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32dev.html
PLATFORM: Espressif 32 (6.1.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
PACKAGES:
- framework-arduinoespressif32 @ 3.20007.0 (2.0.7)
- tool-esptoolpy @ 1.40500.0 (4.5.0)
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Converting airrohr-firmware.ino
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 43 compatible libraries
Scanning dependencies...
Dependency Graph
|-- Wire @ 2.0.0
|-- WiFi @ 2.0.0
|-- DNSServer @ 2.0.0
| |-- WiFi @ 2.0.0
|-- WiFiClientSecure @ 2.0.0
| |-- WiFi @ 2.0.0
|-- HTTPClient @ 2.0.0
| |-- WiFi @ 2.0.0
| | |-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- SPIFFS @ 2.0.0
| |-- FS @ 2.0.0
|-- WebServer @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPmDNS @ 2.0.0
| |-- WiFi @ 2.0.0
|-- OneWire @ 2.3.7
|-- LiquidCrystal_I2C @ 1.1.4
| |-- Wire @ 2.0.0
|-- Adafruit BMP085 Library @ 1.0.1
| |-- Wire @ 2.0.0
|-- Adafruit HTU21DF Library @ 1.0.5
| |-- Wire @ 2.0.0
|-- Adafruit SHT31 Library @ 1.2.0
| |-- Wire @ 2.0.0
|-- DallasTemperature @ 3.9.1
| |-- OneWire @ 2.3.7
|-- SparkFun SCD30 Arduino Library @ 1.0.20
| |-- Wire @ 2.0.0
|-- ArduinoJson @ 6.18.3
|-- ESP8266 and ESP32 OLED driver for SSD1306 displays @ 4.4.0
| |-- Wire @ 2.0.0
|-- TinyGPSPlus @ 1.0.2
Building in release mode
Compiling .pio\build\esp32dev\src\DHT.cpp.o
Compiling .pio\build\esp32dev\src\airrohr-firmware.ino.cpp.o
Compiling .pio\build\esp32dev\src\bmx280_i2c.cpp.o
Compiling .pio\build\esp32dev\src\dnms_i2c.cpp.o
Compiling .pio\build\esp32dev\src\sps30_i2c.cpp.o
Compiling .pio\build\esp32dev\src\utils.cpp.o
Building .pio\build\esp32dev\bootloader.bin
Generating partitions .pio\build\esp32dev\partitions.bin
esptool.py v4.5
Creating esp32 image...
Merged 1 ELF section
Successfully created esp32 image.
Compiling .pio\build\esp32dev\lib9b7\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev\libcf7\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev\liba7b\DNSServer\DNSServer.cpp.o
Compiling .pio\build\esp32dev\libbb1\WiFiClientSecure\WiFiClientSecure.cpp.o
Compiling .pio\build\esp32dev\libbb1\WiFiClientSecure\esp_crt_bundle.c.o
Compiling .pio\build\esp32dev\libbb1\WiFiClientSecure\ssl_client.cpp.o
Archiving .pio\build\esp32dev\lib9b7\libWire.a
C:/Users/andre/Downloads/sensors-software-beta-esp32/airrohr-firmware/airrohr-firmware.ino: In function 'void connectWifi()':
C:/Users/andre/Downloads/sensors-software-beta-esp32/airrohr-firmware/airrohr-firmware.ino:2809:61: error: no match for 'operator=' (operand types are 'WiFiEventFuncCb' {aka 'std::function<void(arduino_event_id_t, arduino_event_info_t)>'} and 'wifi_event_id_t' {aka 'unsigned int'})
WiFiEvent_t::ARDUINO_EVENT_WIFI_STA_DISCONNECTED);
In file included from c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\functional:59,
from C:/Users/andre/.platformio/packages/framework-arduinoespressif32/cores/esp32/HardwareSerial.h:49,
from C:/Users/andre/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:184,
from C:\Users\andre\AppData\Local\Temp\tmp3kboc9yz:1:
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:461:7: note: candidate: 'std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(const std::function<_Res(_ArgTypes ...)>&) [with _Res = void; _ArgTypes = {arduino_event_id_t, arduino_event_info_t}]'
operator=(const function& __x)
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:461:7: note: no known conversion for argument 1 from 'wifi_event_id_t' {aka 'unsigned int'} to 'const std::function<void(arduino_event_id_t, arduino_event_info_t)>&'
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:479:7: note: candidate: 'std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::function<_Res(_ArgTypes ...)>&&) [with _Res = void; _ArgTypes = {arduino_event_id_t, arduino_event_info_t}]'
operator=(function&& __x) noexcept
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:479:7: note: no known conversion for argument 1 from 'wifi_event_id_t' {aka 'unsigned int'} to 'std::function<void(arduino_event_id_t, arduino_event_info_t)>&&'
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:493:7: note: candidate: 'std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::nullptr_t) [with _Res = void; _ArgTypes = {arduino_event_id_t, arduino_event_info_t}; std::nullptr_t = std::nullptr_t]'
operator=(nullptr_t) noexcept
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:493:7: note: no known conversion for argument 1 from 'wifi_event_id_t' {aka 'unsigned int'} to 'std::nullptr_t'
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:522:2: note: candidate: 'template<class _Functor> std::function<_Res(_ArgTypes ...)>::_Requires<std::function<_Res(_ArgTypes ...)>::_Callable<typename std::decay<_U1>::type>, std::function<_Res(_ArgTypes ...)>&> std::function<_Res(_ArgTypes ...)>::operator=(_Functor&&) [with _Functor = _Functor; _Res = void; _ArgTypes = {arduino_event_id_t, arduino_event_info_t}]'
operator=(_Functor&& __f)
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:522:2: note: template argument deduction/substitution failed:
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h: In substitution of 'template<class _Functor> std::function<void(arduino_event_id_t, arduino_event_info_t)>::_Requires<std::function<void(arduino_event_id_t, arduino_event_info_t)>::_Callable<typename std::decay<_Tp>::type, typename std::result_of<typename std::decay<_Tp>::type&(arduino_event_id_t, arduino_event_info_t)>::type>, std::function<void(arduino_event_id_t, arduino_event_info_t)>&> std::function<void(arduino_event_id_t, arduino_event_info_t)>::operator=<_Functor>(_Functor&&) [with _Functor = unsigned int]':
C:/Users/andre/Downloads/sensors-software-beta-esp32/airrohr-firmware/airrohr-firmware.ino:2809:61: required from here
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:522:2: error: no type named 'type' in 'class std::result_of<unsigned int&(arduino_event_id_t, arduino_event_info_t)>'
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:531:2: note: candidate: 'template<class _Functor> std::function<_Res(_ArgTypes ...)>& std::function<_Res(_ArgTypes ...)>::operator=(std::reference_wrapper<_Functor>) [with _Functor = _Functor; _Res = void; _ArgTypes = {arduino_event_id_t, arduino_event_info_t}]'
operator=(reference_wrapper<_Functor> __f) noexcept
c:\users\andre\.platformio\packages\toolchain-xtensa-esp32\xtensa-esp32-elf\include\c++\8.4.0\bits\std_function.h:531:2: note: template argument deduction/substitution failed:
C:/Users/andre/Downloads/sensors-software-beta-esp32/airrohr-firmware/airrohr-firmware.ino:2809:61: note: mismatched types 'std::reference_wrapper<_Tp>' and 'unsigned int'
Compiling .pio\build\esp32dev\lib152\HTTPClient\HTTPClient.cpp.o
*** [.pio\build\esp32dev\src\airrohr-firmware.ino.cpp.o] Error 1
==================================================================== [FAILED] Took 15.33 seconds ====================================================================
Processing esp32dev_de (platform: espressif32; framework: arduino; board: esp32dev)
Library Manager: Installing paulstoffregen/OneWire @ 2.3.7
Unpacking [####################################] 100%
Library Manager: OneWire@2.3.7 has been installed!
Library Manager: Installing marcoschwartz/LiquidCrystal_I2C @ 1.1.4
Library Manager: LiquidCrystal_I2C@1.1.4 has been installed!
Library Manager: Installing adafruit/Adafruit BMP085 Library @ 1.0.1
Library Manager: Adafruit BMP085 Library@1.0.1 has been installed!
Library Manager: Installing adafruit/Adafruit HTU21DF Library @ 1.0.5
Library Manager: Adafruit HTU21DF Library@1.0.5 has been installed!
Library Manager: Installing adafruit/Adafruit SHT31 Library @ 1.2.0
Library Manager: Adafruit SHT31 Library@1.2.0 has been installed!
Library Manager: Installing milesburton/DallasTemperature @ 3.9.1
Library Manager: DallasTemperature@3.9.1 has been installed!
Library Manager: Resolving dependencies...
Library Manager: Installing sparkfun/SparkFun SCD30 Arduino Library @ ^1.0.13
Library Manager: SparkFun SCD30 Arduino Library@1.0.20 has been installed!
Library Manager: Installing bblanchon/ArduinoJson @ 6.18.3
Library Manager: ArduinoJson@6.18.3 has been installed!
Library Manager: Installing ThingPulse/ESP8266 and ESP32 OLED driver for SSD1306 displays @ ^4.2.1
Library Manager: ESP8266 and ESP32 OLED driver for SSD1306 displays@4.4.0 has been installed!
Library Manager: Installing mikalhart/TinyGPSPlus @ 1.0.2
Library Manager: TinyGPSPlus@1.0.2 has been installed!
PACKAGES:
Dependency Graph
|-- Wire @ 2.0.0
|-- WiFi @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- WiFi @ 2.0.0
| | |-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- SPIFFS @ 2.0.0
| |-- FS @ 2.0.0
| |-- WiFi @ 2.0.0
| |-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPmDNS @ 2.0.0
| |-- WiFi @ 2.0.0
|-- OneWire @ 2.3.7
| |-- Wire @ 2.0.0
| |-- Wire @ 2.0.0
| |-- Wire @ 2.0.0
| |-- Wire @ 2.0.0
| |-- OneWire @ 2.3.7
| |-- Wire @ 2.0.0
| |-- Wire @ 2.0.0
Compiling .pio\build\esp32dev_de\src\DHT.cpp.o
Compiling .pio\build\esp32dev_de\src\airrohr-firmware.ino.cpp.o
Compiling .pio\build\esp32dev_de\src\bmx280_i2c.cpp.o
Compiling .pio\build\esp32dev_de\src\dnms_i2c.cpp.o
Compiling .pio\build\esp32dev_de\src\sps30_i2c.cpp.o
Compiling .pio\build\esp32dev_de\src\utils.cpp.o
Building .pio\build\esp32dev_de\bootloader.bin
Generating partitions .pio\build\esp32dev_de\partitions.bin
esptool.py v4.5
Compiling .pio\build\esp32dev_de\lib9b7\Wire\Wire.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFi.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiAP.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiClient.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiGeneric.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiMulti.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiSTA.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiScan.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiServer.cpp.o
Compiling .pio\build\esp32dev_de\libcf7\WiFi\WiFiUdp.cpp.o
Compiling .pio\build\esp32dev_de\liba7b\DNSServer\DNSServer.cpp.o
Compiling .pio\build\esp32dev_de\libbb1\WiFiClientSecure\WiFiClientSecure.cpp.o
Archiving .pio\build\esp32dev_de\lib9b7\libWire.a
Compiling .pio\build\esp32dev_de\libbb1\WiFiClientSecure\esp_crt_bundle.c.o
Compiling .pio\build\esp32dev_de\libbb1\WiFiClientSecure\ssl_client.cpp.o
from C:\Users\andre\AppData\Local\Temp\tmpxdzw2zck:1:
Compiling .pio\build\esp32dev_de\lib152\HTTPClient\HTTPClient.cpp.o
*** [.pio\build\esp32dev_de\src\airrohr-firmware.ino.cpp.o] Error 1
==================================================================== [FAILED] Took 19.57 seconds ====================================================================
Environment Status Duration
esp32dev FAILED 00:00:15.327
esp32dev_de FAILED 00:00:19.567
=============================================================== 2 failed, 0 succeeded in 00:00:34.894 ===============================================================
* The terminal process "C:\Users\andre\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
It is a spell. I am each time the only one able to compile my codes.
I think I remember you must comment out some of the events.
Maybe provide precompiled binaries as well, so the compile-step is not neccessary for testing?
@pjg +1 for precompiled binaries!
I saw the ESP32 (Windows) installer was in beta for a few years now ![]()
Thank you for doing the work!
I have m5Stack Stamp that is esp32 c3u
and I’m getting error
A fatal error occurred: This chip is ESP32-C3 not ESP32. Wrong --chip argument?
I tried to change the platform v to 6.2, but this caused 1T drama
any idea how to fix this?
Thank you in advance
