Drop PM10 requirement for Map
Hi, is it feasible to drop the “minimum PM2.5 and PM10 data” requirement for sensors to appear on the map?
I just added my PMS5003 sensor to this community project (great job, by the way!), but the only reliable values from this sensor are the PM2.5 readings. I suspect sth. similar is true for many other lower-cost sensors as well.
Currently, I am “forced” to publish both PM2.5 and PM10 data, even though I know the latter is inaccurate. Including these unreliable data points likely lowers the overall quality of the project’s dataset.
Feature Request: Allow a sensor to appear on the map if at least one PM data point is provided.
Cheers,
Stephan
