Hi, recently I installed the DNMS and the values in madavi are:
6000000000 dB at DNMS LA max!
in the map:
map seems fine - peaks cleaned?
There is water dripping from the facade just above the sensor on a copper parapet, might be the problem?
Thank you in advance for any hint to assess the issue.
Michael
The graphs at api-rrd.madavi.de aren’t finished yet. So please don’t use them.
Thank you for clarification! Best regards.
Hello, just to point out the grafana details on map for DNMS are having “no data” currently as I know since yesterday. Is it a glitch or are you working on something? Thank you!
Graphs should be back soon. We had to rename the sensor type on some places where we used the german word for noise instead of DNMS.
