Hi All
I’ve had this sensor running for years, but I’m a bit unsure of what the error means?
Looking in Status under
Data Send Return it shows connection failed.
It contains two sensors under ID: 3218617
31730 and 34807
If I look at
https://maps.sensor.community/grafana/d/000000004/single-sensor-view-for-map?orgId=1&var-node=31730
It shows data
If I look at
https://maps.sensor.community/grafana/d/000000004/single-sensor-view-for-map?orgId=1&var-node=34807
It shows data.
It’s a 280 and not a 180, and I changed it in the config (I recently replaced it), but it doesn’t reflect it in the display or on my account?
I collect the data locally as well, both in Home Assistant and InfluxDB and that seems to work fine.
The sensor is set on a WLAN specific for IOT devices, with a short SSID, and a shorter password, and the wifi connection looks healthy.
