Data missing in archive and sensor not visible on map (ID: 16173571)
I have a problem with my sensor (Node ID: esp8266-16173571).
It was registered in March 2024, but looking at the archive (https://archive.sensor.community/), I can only see data for 2024. There is no data for 2025 or 2026, and the sensor is currently missing from the map.
In my devices dashboard, the “Last Update” is shown as 2024-03-07. However, the sensor has been powered on this whole time.
Sensor details:
  • Board: ESP8266
  • Sensors: SDS011 (ID: 86420), BME280 (ID: 86421)
Could you please check if there are any issues with this Node ID on the server side? Or perhaps the sensor was somehow deactivated?
Thank you!
could you please check that the sensor.community API is active in your local device settings?
You could also try to deactivate https for this API.
