CSV archives - geolocation mismatch
Hi all,
I’m trying to crunch some numbers and wanted to get the csv files from the archives for my sensors and I’m not sure I’m doing it right.
My chip and sensor IDs are :
I tried searching for both, and chip ID cannot be found in archives (too long) but I was able to find the sensor number - 43621
However, if I grab BME280 data for my sensor number, e.g. 2023-01-23_bme280_sensor_43621.csv and open it, LAT/LON values do not match with mine so I’m guessing this is not my data. So how do I find my data that match my sensor number and my geolocation as well?
Also, my other sensor is missing from the archives (SDS011), at least for 23rd of December so where do I find data for that one?
Thank you for any insights on this!
It is not the Sensor ID!
Click on data or check the map.
It is not the sensor ID but it is sensor ID :slight_smile:
I was able to find it, I had to use specific sensor ID from Data section:
Thank you @pjg
