Could you help me and give me tint, what is proper wiring for GPS module NEO 6M. I google that should be connected RX/TX to D3 and D4, but also found that should be D5 and D6.
In fact I connected it to D5 RX and D6 TX, but looks that without success (same as for D3/D4) GPS module is powered blue LED is blinking every second, but when I check my devices there is not information about GPS data.
Could you support me within this topic?
So it means that I have it connected it in proper way.
No, I haven’t; all of the programming I know some basics but it is not the strongest part of my knowledge
I understand that GPS data are not visible on website, but in such case, shouldn’t I see at least on my devices screen some data about position? I mean in the area marked on attached pic?
As I wrote I connected RX → D5 and TX → D6. It looks for proper connection as you have shown in the code and yes I connected also power GND, so do VCC. However not to 5V, but to 3V, but as I read it is possible to power it from 3V.
Far now all of the trials I did somehow indoor, because I had ESP with GPS module on the window sill (outside). I have it turned on around 1-2h.
The only thing which I have now in mind is doubt considering antena
I have it connected in the way as on the picture. But as I see some pics in internet it it is sold to the plate from opposite side. Should I do that also or might it stay as it is?
Did and now I’m receiving GPS data. So thanks for this tint, it is working. No issue with receiving GPS coordinates even inside of flat, no need to put sensor close to the window sill
