Connecting new Rasp Pi/Enviro+ to Sensor Community
All,
I’m a newbie but I’ve gone through the normal simple explanations for errors and I can’t find out what’s wrong.
I’ve successfully loaded the appropriate scripts onto the Pi and I’m getting output onto my MacBook Terminal.
I’ve also established / registered with Sensor Community using the instructions and avoiding the pitfalls noted by others.
What isn’t happening is any update either on the My Sensor page or on the map? - I’ve gone round the houses and I’m bit stuck on where my error is (it will be mine!).
Any help appreciated.
Goudie Berry!
Which code did u use for the raspberry. Is ist well configured to send to the API with the right X-pin? What about the sensors choosed in devices.sensor.community ?
I would tell that anyything different from the official instructions should be reserved to very advanced users… I can t say anything about debugging on a raspberry. Or send me one :rofl:
May I ask where are the official instructions?
I just registered and the page with guidelines Configure air quality sensor yourself has links only to https://sensor.community, to maps and archive. There are no other instructions links.
@sikorka For the installation instructions of the Enviro+ you need to look at “An outdoor air quality station with Enviro+ and Luftdaten” . This is a product maintained by Pimoroni, not us.
Thank you for your answer.
I mean official instructions. Because I have Enviro+ / PMS5003 with Raspberry Pi Pico W, not with Raspberry Pi.
I just need to know where are API descriptions and how to make calls, if there is some auth to do etc.
In the mean time I will look at the code from article you sent.
Thank you!
Hi @sikorka you can find an API description on how to send data to us at EN APIs · opendata-stuttgart/meta Wiki · GitHub
There is no auth, you only need to register your device first at https://devices.sensor.community/ . You should use “raspi” as sensor board and the serial no. of the CPU as the sensor ID.
Thank you so much!
I checked the docs and my calls seem legit.
I took the serial number from Pico as the C code returns it and ofc preceeded it with raspi-.
Pico Enviro+ comes with a bit higher version than BME280. I didn’t know how to select the BME688, so it is left with BME280.
Anyway it works! So exciting :slight_smile:
@sikorka , based on your work, I wrote a destination for the official firmware: feat: Add Sensor.Community data destination by fangfufu · Pull Request #237 · pimoroni/enviro · GitHub. Thanks for the inspiration.
