I bought a BME680 instead a BME280, can i use either? i think yes, because only want to read TEMP and HUM
@josecmorales you can try to use the BME680. But I think that there were changes in the protocol used by this sensor as there are now more values (VOC, iAQI). So it’s more likely that it won’t work.
Yes, it doesnt works! ![]()
How did you connect the BME680 to the unit?
Just using the same 4 wires as with the 280?
have the same, like BME280!
