BME280 data not send through
L.S.,
For some reason PM data (SDS011) is recieved and shown at Samen Meten - Dataportaal, but BME280 data is not. While it shows here at sensor.community.
Is this normal, as I see some at Samen Meten - Dataportaal that show data of both…
Am I doing something wrong?
Thanks for your time.
With kind regards,
JvB
Same here. But it worked for 30 hours.
Could you please ask Samen Meten about this?
Normally they use the same data stream we use for our map. So if you can see the BME280 data on our map then this data should also be available for Samen Meten.
@ricki-z : Thanks for your quick response. As I can see all BME data here, I’ll check with Samen Meten.
I’ll keep this thread updated
Well, I’m not sure how it happend, but the BME280 is also visible now.
