Hi everyone,
I’d like to know if it’s possible to “program” an alarm that is released when the air quality goes over a certain amount. For example, an email alarm whenever the air quality goes over 30 micrograms…
Kind regards,
Ben
Are you still interested in this feature? I am currently working on this feature. For me the best way is to integrate the sensor in my Home Assistant (HA) domotica system. It is now one of the many sensors that are monitored by HA. HA provides you with support for sending e-mails, controlling actuators, etc.
This solution is extra to sending the data to the sensor community. So you have both local access to the data as well as storage in the sensor community database.
If there is interest, I will publish here how this works.
Thank you very much @RuudvanMunsterZTM !
I’d be very happy if you could publish some instructions. ![]()
A good way to start is to run the following command from a terminal, for example “cmd”:
curl http://<sensor IP address>/data.json > sensordata.txt
You will then get a data file that looks like this (depending on the type of your sensor):
{"software_version": "NRZ-2020-133", "age":"118",
"sensordatavalues":[
{"value_type":"SDS_P1","value":"17.35"},
{"value_type":"SDS_P2","value":"9.60"},
{"value_type":"BME280_temperature","value":"7.12"},
{"value_type":"BME280_pressure","value":"103936.44"},
{"value_type":"BME280_humidity","value":"62.25"},
{"value_type":"samples","value":"5060693"},
{"value_type":"min_micro","value":"28"},
{"value_type":"max_micro","value":"20128"},
{"value_type":"interval","value":"145000"},
{"value_type":"signal","value":"-40"}
This is a good start to understand the data structure of the sensor’s output. You also need this to know how the JSON file is received by Home Assistant (if you want to integrate your sensor into this domotic environment) and which data is contained in which item.
I have two different air quality sensors and they both have a different data structure for the JSON file.
In Home Assistant you can create a sensor template that organizes the collection of data for you. For those who are familiar with Home Assistant. That template looks like this:
- platform: command_line
name: "Air Quality Aside PM10 (SDS)"
command: 'curl http://192.168.178.20/data.json'
value_template: "{{ value_json.sensordatavalues[0].value | round(1) }}"
unit_of_measurement: "µg/m³"
name: "Air Quality Aside PM2.5 (SDS)"
value_template: "{{ value_json.sensordatavalues[1].value | round(1) }}"
name: "Air Temperature Aside (BME280)"
value_template: "{{ value_json.sensordatavalues[2].value | round(1) }}"
unit_of_measurement: "°C"
name: "Air Pressure Aside (BME280)"
value_template: "{{ value_json.sensordatavalues[3].value | round(1) }}"
unit_of_measurement: "Pa"
name: "Humidity Aside (BME280)"
value_template: "{{ value_json.sensordatavalues[4].value | round(1) }}"
unit_of_measurement: "%"
name: "Air Quality Aside Samples"
value_template: "{{ value_json.sensordatavalues[5].value | round(1) }}"
unit_of_measurement: ""
name: "Air Quality Aside Min_Micro"
value_template: "{{ value_json.sensordatavalues[6].value | round(1) }}"
name: "Air Quality Aside Max_Micro"
value_template: "{{ value_json.sensordatavalues[7].value | round(1) }}"
name: "Air Quality Aside Interval"
value_template: "{{ value_json.sensordatavalues[8].value | round(1) }}"
name: "Air Quality Aside WiFi Signal Strength"
value_template: "{{ value_json.sensordatavalues[9].value | round(1) }}"
unit_of_measurement: "dBm"
I find the numbering …sensordatavalues[9]… etc. a weak part of this solution.
You would rather have something like …sensordatavalues[“signal”]… etc.
I’m still looking for that.
This was assuming that you are using an environment like Home Assistant. You could also make something yourself in Python to decode the JSON file and send a message based on that. But if you like this kind of automation, Home Assistant is well worth considering.
The sensor is still sending its data to the Sensor Community site, so the data is still available there for research.
Currently I have some issues with one of my sensors. There is a posting about that on this forum as well.
This should be easy to do. I use an app called Pushover to send push notifications to my devices so you could write a script to send a notification if a value goes above a level.
they made an integration…
That’s correct. I prefer to have my sensordata directly from the sensor into Home Assistant. E.g. for control of opening/closing windows. In addition, at the time I created this interface, the data of Sensor Community was often not available due to server problems.
maybe you should post your code to home assistant forums…
That’s my intention. As I wrote earlier in this topic, my current code is not very suitable for distribution. It works in my specific situation. I want to make it a bit more generic and more resistant to transmission and sensor errors. Unfortunately I haven’t had enough time for that because I’ve been very busy with a tool to visualize particulate matter from a sensor. ![]()
Digital Pollution Painter
Unfortunately in Dutch, maybe Google translate helps enough…
the last hours server is down… pls upload the code to home assistant site ![]()
