airRohr wifi default password doesn't work
Hi! I’ve been trying to change the wifi setting of my SDS011. I restarted it, so the airRohr-xxxxx SSID appeared, however it asks for password. The default airrohrcfg doesn’t work.
Is there any way to reset the settings of the device?
Try a serial monitor (putty) on your USB connector.(some messages)
If nothing works you can erase your sensor and upload Firmware again.
All your setting are lost
