Firmware en.bin
Connected it to my wifi network and is working
On the webpage I can see the measured data
Went to devices.sensor.community and registered the sensor as ESP32-8358555
For information: this is the second ESP32 I took and still got the same error
The first sensor I deleted and cannot reuse the esp32 for sensors anymore… just standalone, because I cannot re-register the same number again…
What information should i give more to troubleshoot this error??
Is it possible that a particle sensor SDS011 must be connected, I can do it, because I have one spare.
I wanted to create a amount of sensors to observe just temperature and humidity to mount into greenhouses.
As I always say : if you don’t know exactly what you do, you should not deviate from the official instructions. It is always the same…
Did you configure the same sensors in both devices.sensor.community and in the config interface on your WiFi network.
I try to find the ID ESP32-8358555 without success. Can you send me a screenshot of the configuration interface ? Are you 100% sure the sensor is connected to the WiFi network ?
AND: Sensor.Community is about collecting environmental data for the community, it should not be a system to check temperature and humidity in greenhouse installations… Or maybe you want to send us some fresh tomatoes (or an other kind of smelly plant…) ?
@F4VSJ Hello, are you sure that you have an ESP32? The chipID looks like an ESP8266. And if you used our flashing tool and the software provided by this tool then it is an ESP8266.
Pierre Jean,
Well you are right… on the chip is written ESP8266MOD like on the picture…
I’ll change the config ans see if I find the sensor then
Thanks for giving me the right direction
Is there a possibility to change the esp32 to ESP8266???
When I delete the sensor in the devices list, than I cannot re-enter the same serial number…
Any good idea??
@F4VSJ (cc @pjg) you can register the chipID ‘again’. This only won’t work if you use this ID with the same type (registering as ESP8266, delete this and register as ESP8266 again).
Thanks a lot, I’ll change it when I’m at home again
For the moment working on other air-rohr sensor in the FABLAB of Rostrenen
This is in the west part of France , named Britany.and there we are real in the center of Britany
hans
