After the last week’s downtime (the SSL incident), I’ve updated my Airrohr-Sensor. It works like a charm and the data can be seen on map.sensor.community. Only the connection to OpenSenseMap seems to be broken.
I’ve double-checked the senseboxID and double-checked if OpenSenseMap is enabled in the config. In the debug log, I can find the following:
## Sending to sensor.community - BME280
## Sending to opensensemap:
Time for Sending (ms): 107
Any ideas on how to debug this issue? Is there a kind of log interface at OpenSenseMap?
Opensensemap indeed uses a Let’s Encrypt certificate which was renewed on March 16th without the X3 cross-signing so HTTPS uploads from the released firmware to opensensemap will fail.
Unfortunately the current SC-firmware (both release and beta) have HTTPS for the OpenSenseMap API hardcoded and it can’t be disabled in the UI.
Upgrading the SC firmware of a ‘Luftdaten’-setup to deal with this aspect seems the best idea, but reluctant to ‘fiddle’ with patched firmware, because knowing the limits of my capabilities: do not touch what is working …
Instead looking for a ‘general’ work-around:
is a small (Python**?**) script available with following 3 functions?
a. locally read the device by url-call http://ip-address/data.json
b. recompile the info from the resulting json-file for compatible upload to opensensemap
c. periodically perform that upload
Interested to participate in this kind of solution.
I understand the “do not touch what is working” sentiment. However this and other fixes and features are available in the current official release of the firmware NRZ-2024-135 since Apr 9 2024. That version works on more than 11000 installed sensors so you might consider installing the official firmware.
Normally yes but this specific beta version (NRZ-2021-134-B4) has a bug in the automatic updating so won’t auto-update. You’ll have to manually re-flash.
Hey @Phaze-III
I’m having the very same issue - I got my device setup and working properly when it comes to sending the data to Sensor.community, but getting the
Time for Sending (ms): 405
My current version is quite old - NRZ-2020-133/EN (Nov 30 2020) - but whatever I tried, I can’t get it to be detected properly on neither my Mac and Windows PC. It just appears as generic USB device, no matter how and what drivers I install. Is there any way to initiate the on-fly firmware update via WiFi?
I have
Firmware version Auto update firmware
Load beta firmware
ticks checked, but they don’t seem to work properly.
I’ve resolved the issue by finally being able to connect to the sensor and flash the firmware by cable.
Problem with my NodeMCU board was that even though it was explicitly written on it “Install CH340G drivers”, it appeared as FTDIBUS\COMPORT&VID_0403&PID_6001 which meant I needed proper FTDI drivers instead of CH340G
One workaround might be to load linux as a virtual machine and pass-through the board as a usb device. Typically the driver would be part of the kernel so, more often than not, it will find the right one on its own. No need to hunt for the right one.
