I am comparing one of my sensors SDS011 with an Ecowitt WH41.
Some notes:
- I limit my compare to PM 2.5 only and omit AQI.
- both sensors are located on the roof of a house over 2 meters high from the peak without obstacles
- 12m height from the ground
- there are no official ARPA tracking stations nearby to extende may compare
- the Wcowitt WH45 sensor is not significant (inside an house at 50 meters), it’s only informative
- As soon as I solve the power problems, I will make comparisons over longer times
In all tests and in this example, there is an average difference between the two sensors (WH41 gives 50% higher data on average).
I do not have a certain reference that allows us to understand if WH41 overestimates or SDS underestimates.
What do you think?
