Hi, ESP8266 with SDS011+DHT22 here.
I am trying to connect the device to a WiFi via WPA2 Enterprise. I’ve found in this forum that this may not be supported, only WPA PSK allowed.
I’ve also ended up onto this script https://gist.github.com/Matheus-Garbelini/2cd780aed2eddbe17eb4adb5eca42bd6 that may do the trick but implementing it in the airrohr firmware is quite far from my skills.
Is there any work around, any suggestion to connect the device to a WPA2 Enterprise WiFi connection?
