Using Arduino LoRa network on the sensor community project?
Hello, I’m using my own gateway and the connection between the sensor and the gateway is working fine. Here’s my latest version of the webhook, but it’s still not working. I found this discussion with this GitHub project; do you think it would be helpful for my situation?
https://forum.sensor.community/t/integration-ttn/1248/2
https://github.com/bertrik/sensor-data-bridge
<?php
// DevEUI du capteur à traiter
$allowed_dev_eui = '-----i hide it----';
// Lire le JSON envoyé par TTN
$input = file_get_contents('php://input');
// Débogage : sauvegarder le JSON brut pour vérification
file_put_contents('debug_ttndata.json', $input.PHP_EOL, FILE_APPEND);
// Décoder le JSON
$data = json_decode($input, true);
// Vérifier si uplink_message et frm_payload existent
if (!isset($data['uplink_message']['frm_payload'])) {
    http_response_code(400);
    echo "Missing frm_payload";
    exit;
// Vérifier que le DevEUI correspond
$dev_eui = $data['end_device_ids']['dev_eui'] ?? '';
if ($dev_eui !== $allowed_dev_eui) {
    echo "Unknown device";
    exit;
// Décoder le frm_payload (base64)
$payload_base64 = $data['uplink_message']['frm_payload'];
$payload_bin = base64_decode($payload_base64);
// Supposons que le payload contient 4 floats de 4 bytes chacun (ex: température, humidité, pression, autre)
$values = [];
if (strlen($payload_bin) === 16) { // 4 floats * 4 bytes
    for ($i = 0; $i < 4; $i++) {
        $chunk = substr($payload_bin, $i*4, 4);
        $values[] = unpack("G", $chunk)[1]; // "G" = float 32-bit big endian
// Ici tu peux envoyer $values vers ta base ou Carto
// Exemple simple : sauvegarde CSV
$line = date('c') . ',' . implode(',', $values) . PHP_EOL;
file_put_contents('sensor_data.csv', $line, FILE_APPEND);
http_response_code(200);
echo "OK";
