SPS30 having same value
I’m facinig issue while using SPS30 sensor.
PM2.5, PM4 and PM10 have same value and values are changes for all three PM.
Please help me with the issue
INFO : Word[0]: 04 92 59 → 1170. PM1.0
INFO : Word[1]: 04 CB AF → 1227. PM2.5
INFO : Word[2]: 04 CB AF → 1227 PM4.0
INFO : Word[3]: 04 CB AF → 1227. PM10
INFO : Word[4]: 1E 56 5A → 7766
INFO : Word[5]: 23 AE 93 → 9134
INFO : Word[6]: 23 E4 75 → 9188
INFO : Word[7]: 23 E6 17 → 9190
INFO : Word[8]: 23 E8 08 → 9192
INFO : Word[9]: 01 41 79 → 321
INFO : NEW DATA AVAILABLE
INFO : SPS30 READ DATA
INFO : Word[0]: 01 C3 61 → 451
INFO : Word[1]: 01 D9 F9 → 473
INFO : Word[2]: 01 D9 F9 → 473
INFO : Word[3]: 01 D9 F9 → 473
INFO : Word[4]: 0B B1 15 → 2993
INFO : Word[5]: 0D C0 86 → 3520
INFO : Word[6]: 0D D5 30 → 3541
INFO : Word[7]: 0D D5 30 → 3541
INFO : Word[8]: 0D D6 63 → 3542
INFO : Word[9]: 01 46 EE → 326
Hi and welcome.
This is more or less normal behavior of the SPS30 (and other Sensirion sensors). They are relatively good at measuring PM1 and PM2.5 but not so much for PM4 and PM10.
There are many posts on this forum about this. What sensors can be used? - #33 by ElCollau has a likely explanation why this happens.
Basically PM4 and PM10 are estimates based on some hard-coded algorithm which decides that (based on the difference between PM1 and PM2.5) there aren’t (m)any larger particles and since the PM4 and PM10 values include all lower counts these values are then the same as PM2.5.
I don’t have an SPS30 but you could test the above explanation by exposing the sensor intake to some coarse dust (sawdust, vacuum cleaner dust…) and see what happens.
I do have an SPS30 and I’m seeing exactly the same:
Sensirion SPS30 PM1 27.2 µg/m³
Sensirion SPS30 PM2.5 28.9 µg/m³
Sensirion SPS30 PM4 29.0 µg/m³
Sensirion SPS30 PM10 29.1 µg/m³
I’ve rarely seen a bigger difference between these values.
I’ve accepted that the pm10 value is just not very reliable.
