Hello @Mathias , I’ve released the chipID.
Hallo @winstonoboogie , ich habe die chipID freigegeben.
Hallo @tittelm , ich habe die chipID freigegeben.
Hello @leo , please retry the registration. You should check that you only select one component per type when changing the default sensors (i.e. no 2 PM sensors). This is causing the same error message.
Thank you, I try to register my device again.
Ik heb mijn sensor met ID: 246364 verwijderd. Gelieve dit handmatig af te ronden.
Met dank
Hervé Tavernier
I have removed my sensor with ID: 246364. Please complete this manually.
Kind regards,
Hervé Tavernier
Hello @Herve , there is no registration with that chipID. Could you please check the chipID?
Hello, trying to register ID 6433170 but it reports “This sensor ID is already registered” although I do not see it under my sensors. Thanks!
