Hello, I would like to change in mijn account settings my email adres. How can i do that,
gr Piet
gr Piet
This is not possible at the moment (or better not directly …).
What you can do:
Hello Ricki, I made a mistake in de numbering of de ID number in my sensors. How can I change that number.
thanks in advance
Greeting Piet
Hello Ricky, we have a participant in our database who is not going to use his sensor. He doesn’t trust security. He is a lawyer by profession. They may have always been suspicious. He has never activated the sensor in his WiFi environment and wants to give it back so that we can use the sensor with someone else. Since I have already transferred the sensor to him and he has lost that mail, the meter cannot be transferred back, so I can put the meter back in my domain to redistribute. This is a sensor with the ID number 8022679
Is there some sort of reset possible? Flashing again didn’t do anything because the sensor ID number already exists. The solution seems to me that the sensor is removed from the database so that I can register it again. Is that possible or is there another way to fix this?
Thanks in advance for your response.
Greetings Piet van Schijndel
The meter ID is 8022679 the sensor ID nr on the map 59780
Thx Ricki, second question, do you know why this site is hardly reachable?
https://devices.sensor.community/my-sensors
I can’t configure my sensors or hand them over to the clients.
Thanks in advance.
Greetings Piet
Can you try it again. Sometimes there are processes that aren’t finished correctly. These processes cause too much load and may slow down the site.
He Ricky it works very fast. Thx for this very fast service. My compliments.
Gr Piet
Hello Ricky, can you remove the registration of meter ID 151605 with sensor ID 58210, so we can program it like new? Thanks in advance.
